I get errors installing icinga2 and don’t know what to do.
I installed icinga2 on my debian 11 vm. At the beginning the most things work find but i made some config errors and decided to uninstall it and make a new start. But now I get the following errors:
apt-get install icinga2
libboost-regex1.74.0:amd64 (1.74.0-9) is set up ...
libboost-context1.74.0:amd64 (1.74.0-9) is set up ...
dpkg: Dependency issues prevent configuration of icinga2-bin:
icinga2-bin depends on icinga2-common (= 2.13.7-1+debian11); but:
Package icinga2-common is not yet configured.
dpkg: error when editing package icinga2-bin (--configure):
Dependency problems - remains unconfigured.
libboost-thread1.74.0:amd64 (1.74.0-9) is being set up ...
dpkg: Dependency issues preventing configuration of icinga2:
icinga2 depends on icinga2-bin (= 2.13.7-1+debian11); but:
Package icinga2-bin is not yet configured.
icinga2 depends on icinga2-common (= 2.13.7-1+debian11); but:
dpkg: error when editing package icinga2 (--configure):
libboost-coroutine1.74.0:amd64 (1.74.0-9) is set up ...
Triggers for man-db (2.9.4-2) are processed ...
Triggers for libc-bin (2.31-13+deb11u5) are processed ...
Errors occurred while processing:
icinga2-common
icinga2-bin
icinga2
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@meurodebian:/etc/apt/sources.list.d# ^C
root@meurodebian:/etc/apt/sources.list.d# apt-get install icinga2-common
Package lists are read... Done
Dependency tree is built... Done
Status information is read in... Done
icinga2-common is already the latest version (2.13.7-1+debian11).
icinga2-common was set as manually installed.
0 updated, 0 reinstalled, 0 to remove and 0 not updated.
3 not completely installed or removed.
Can someone please help.
