Ansible with Icinga Director 1.10.x - t_systems_mms.icinga_director
Looking att blogposts, docs and the t_systems_mms.icinga_director project I was thrilled to start automate my fresh install of a single master. I have allready got my bootstrapping of icinga2, icingaweb2, director, icingadb and the dependencis needed - with ansible, works great.
When I try to use the t_systems_mms.icinga_director collection to declare basic structure for service/host templated I got stuck. I used the docs and can use curl to create stuff and deploy to director but when using the collection with ansible it fails. First question, is the t_systems_mms.icinga_director collectiion compatible with director 1.10.x?
As far as I can see they has an issue regarding director after upgrading from 1.8 to 1.10 Error when modifying service apply rules after director update 1.8 > 1.10 · Issue #190 · T-Systems-MMS/ansible-collection-icinga-director · GitHub
I hope some of you have experience of this matter, thank you.
Could you post your ansible code? it would be easier to debug.
Yes, mostly, except for the issue you linked. :slight_smile:
I use examples from the git repo: ansible-collection-icinga-director/icinga_service_template.yml at master · T-Systems-MMS/ansible-collection-icinga-director · GitHub
Ok, great news, what is the bare minimum for ex creating a base service template running ansible from my laptop? Using hosts: localhost exits with fatal: [localhost]: FAILED! => {“changed”: false, “msg”: “bad return code while creating: 404. Error message: HTTP Error 404: Not Found”} using an inventory file with my icingaweb2 server does the same. I assume its me not understand how to use the collection :slight_smile:
I did some more testing, got it to work creating a basic service template (had missed that I had to use the full url to icingaweb2 included, ex https://master.example.com/icingaweb2), added one more task to apply the changes to director, got an error module not excists, then I noticed the latest realese, 1.33.0 (used 1.32.2 before) updated to latest, then the icinga deploy module started to work! Great! I have to do some more extended testing but it looks like it works now :slight_smile: Is it possible to read about changes included when new versions of the collection is realesed?
Go to the git repo and watch for releases. Then you will get notified if a new release is pushed:
