Hi!
This morning I updated our Icinga2 environment and now I’m running into a dependency cycle error. I’ve read the documentation several times, but I can’t seem to figure out how to fix this. Hopefully someone of you can help me out.
This is the error I got:
[2023-07-17 10:33:21 +0200] critical/config: Error: Dependency cycle:
Service 'hostname.example.com!VHOST_extra_uri_to_check.tld'
-> Dependency 'hostname.example.com!VHOST_extra_uri_to_check.tld!HTTPS_CERTIFICATE'
-> Service 'hostname.example.com!HTTPS'
-> Dependency 'hostname.example.com!HTTPS!HTTPS_CERTIFICATE'
[2023-07-17 10:33:21 +0200] critical/cli: Config validation failed. Re-run with 'icinga2 daemon -C' after fixing the config.
* checking Icinga2 configuration. Check '/var/log/icinga2/startup.log' for details.
Some of our hosts have an extra separate HTTPS service to check an other domain. Only it seems to go wrong here with the dependency that is set for the HTTPS_CERTIFICATE service.
This is the host configuration:
object Host "hostname.example.com" {
import "generic-host"
vars.check_address = "xx.xx.xx.xx"
vars.check_address_type = "IPv4"
vars.check_http_enabled = true
vars.check_http_vhost = "uri.example.com"
vars.check_https_enabled = true
vars.check_https_vhost = "uri.example.com"
object Service "VHOST_extra_uri_to_check.tld" {
import "generic-service"
host_name = "hostname.example.com"
check_command = "check_http"
vars.check_http_vhost = "extra_hostname_to_check.tld"
And these are the services:
apply Service "HTTPS" {
assign where host.vars.check_https_enabled == true
ignore where host.vars.check_https_enabled == false
vars.check_http_port = "443"
vars.check_http_ssl_enabled = true
vars.check_http_ssl_version = "$check_https_version$"
vars.check_http_string_expected = "$check_https_string_expected$"
vars.check_http_content_expected = "$check_https_content_expected$"
if (host.vars.check_https_vhost) {
vars.check_http_vhost = "$host.vars.check_https_vhost$"
} else {
vars.check_http_vhost = "$host.name$"
if (host.vars.check_https_uri) {
vars.check_http_uri = "$host.vars.check_https_uri$"
} else{
vars.check_http_uri = "/"
apply Service "HTTPS_CERTIFICATE" {
import "slowalarm-service"
check_command = "check_ssl_cert"
ignore where host.vars.check_https_cert_check == false
vars.check_https_ssl_warn = "7"
vars.check_https_ssl_crit = "2"
vars.check_https_vhost = "$host.vars.check_https_vhost$"
} else {
vars.check_https_vhost = "$host.name$"
apply Dependency "HTTPS_CERTIFICATE" to Service {
parent_service_name = "HTTPS"
disable_checks = true
disable_notifications = true
assign where service.vars.check_https_enabled == true
I’ve already tried several things with the redundancy_group option, but unfortunately I haven’t found the solution yet.
Anyone have an idea how I can solve this?
Thanks in advance!
