This looks like HTTP 404. Are you sure the API is accessible on plain text port 8080? By default this is port 5665 and needs https connection. Also the user has to be added to api-users.conf.
thanks. Its problem was number port. now it shows another problem “the target ser ver failed to respond” (attached screenshot) . I created user on ApiUsers.conf like you say (attached screenshot).
