I am facing an issue since 2 weeks now and can’t find a solution. I hope one of you can help me.
I installed ncpa on my Proxy and want to run the checks.
What I found so far is:
First when I check with if ncpa is running: systemctl status ncpa_listener
I get the reponse that the service is running but (exited) Active: active (exited) since Tue 2020-08-04 14:26:11 CEST; 22h ago
second when I run the check on icinga with the verbose flag I get this error: An error occurred:<urlopen error [Errno 111] Connection refused>
I hope anyone has an idea what could cause the problem.
Thank you in advance
