Hi Roland,
Here is our icinga version on parent side
I got the image iof Icinga 2 from Docker Hub
What would be the right solution. I’m planning to fix this server and install another one in other location to monitor different agents and also monitor our current Icinga Parent .
Thanks Roland,
Do you recommend to downgrade the agent one or upgrade Master to higher version?
How easy would be the upgrade 2.10.5.1 to the latest version? can you share with me your thoughts or any helpful link. I tried to downgrade the agent and didn’t have any luck on installing icinga2 2.10.4.1 on centos 7.
I prefer to have the latest version installed (since there are often bug fixes). Upgrading is most of the time just let your package manager do its job. And it is highly recommended to read upgrading docs before.
