Does every alert has some sort of uniqueness in terms of a key or value to associate it with a specific result ? something similar to Prometheus.
e.g. For “check_disk” plugin , it will alert for any mounted filesystem on a Linux host. When it alerts for “/” is above a defined threshold and the gets subsequently resolved only for “/” filesystems. I’m looking for this relationship to be specific.
I couldn’t find a reference in the documentation.
Please advise,
