remove buisnessorocess and get new. In git typed 2.3.1. When make by manual from git I have branch master, but in icinga typed 2.3.0. vsheredb is 1.1.0. Problem still exist. reboot server and clean cache maked, but it don’t help
@Edekrusher Please share the output of the following command (Run it where Icinga Web 2 is installed):
icingacli module list installed --verbose
MODULE VERSION STATE DIRECTORY
businessprocess 2.3.0 enabled /usr/share/icingaweb2/modules/businessprocess
cube 1.1.1 disabled /usr/share/icingaweb2/modules/cube
dependency_plugin 0.0.0 enabled /usr/share/icingaweb2/modules/dependency_plugin
director master enabled /usr/share/icingaweb2/modules/director
doc 2.9.0 disabled /usr/share/icingaweb2/modules/doc
grafana 1.4.2 disabled /usr/share/icingaweb2/modules/grafana
graphite 1.1.0 enabled /usr/share/icingaweb2/modules/graphite
icingadb 1.0.0-rc1 disabled /usr/share/icingaweb2/modules/icingadb
idoreports 0.9.1 enabled /usr/share/icingaweb2/modules/idoreports
incubator 0.6.0 enabled /usr/share/icingaweb2/modules/incubator
ipl v0.5.0 enabled /usr/share/icingaweb2/modules/ipl
lsd 1.0.1 disabled /usr/share/icingaweb2/modules/lsd
map 1.1.0 disabled /usr/share/icingaweb2/modules/map
mapDatatype 0.1.0 enabled /usr/share/icingaweb2/modules/mapDatatype
migrate 2.8.0 disabled /usr/share/icingaweb2/modules/migrate
monitoring 2.8.0 enabled /usr/share/icingaweb2/modules/monitoring
nagvis 1.1.1 disabled /usr/share/icingaweb2/modules/nagvis
pdfexport 0.9.1 enabled /usr/share/icingaweb2/modules/pdfexport
pnp 1.1.0 enabled /usr/share/icingaweb2/modules/pnp
reactbundle 0.7.0 enabled /usr/share/icingaweb2/modules/reactbundle
reporting 0.10.0 enabled /usr/share/icingaweb2/modules/reporting
setup 2.9.0 disabled /usr/share/icingaweb2/modules/setup
test 2.8.0 disabled /usr/share/icingaweb2/modules/test
translation 2.9.0 disabled /usr/share/icingaweb2/modules/translation
vsphere 1.1.0 enabled /usr/share/icingaweb2/modules/vsphere
vspheredb 1.1.0 disabled /usr/share/icingaweb2/modules/vspheredb
x509 1.0.0 enabled /usr/share/icingaweb2/modules/x509
I have something like this in my logs, i wonder if this is a related issue
<br />
<b>Fatal error</b>: Uncaught Less_Exception_Parser: Expected ']' got 'i' in anonymous-file-0.less in /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php:2653
Stack trace:
#0 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(878): Less_Parser->Error('Expected ']' go...')
#1 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(1823): Less_Parser->expectChar(']')
#2 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(781): Less_Parser->parseAttribute()
#3 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(1694): Less_Parser->match(Array)
#4 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(1772): Less_Parser->parseElement()
#5 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(1751): Less_Parser->parseSelector(true)
#6 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(1867): Less_Parser->parseLessSelector()
#7 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(799): Less_Parser->parseRuleset()
#8 /usr/share/i in <b>/usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php</b> on line <b>2653</b><br />
Downgrading to 2.8.4 fixes the issue.
in console google chrome errors:
icinga.min.js:15 GET http://icinga.monitor.trk.local/cube?dimensions=type&showSettings=0&showCompact=1 404 (Not Found)
send @ icinga.min.js:15
ajax @ icinga.min.js:15
loadUrl @ icinga.min.js:587
(anonymous) @ icinga.min.js:677
each @ icinga.min.js:15
loadDashlets @ icinga.min.js:677
dispatch @ icinga.min.js:15
v.handle @ icinga.min.js:15
trigger @ icinga.min.js:15
(anonymous) @ icinga.min.js:15
onInit @ icinga.min.js:674
initialize @ icinga.min.js:458
(anonymous) @ icinga.min.js:457
t @ icinga.min.js:15
setTimeout (async)
c @ icinga.min.js:15
fireWith @ icinga.min.js:15
fire @ icinga.min.js:15
ready @ icinga.min.js:15
B @ icinga.min.js:15
icinga.min.js:462 11:43:53.355 404 Not Found: Страница не найдена. Включение модуля “cube” может помочь!
writeToConsole @ icinga.min.js:462
error @ icinga.min.js:462
onFailure @ icinga.min.js:649
l @ icinga.min.js:15
load (async)
setTimeout (async)
DevTools failed to load source map: Could not load content for http://icinga.monitor.trk.local/js/vis.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
This is a syntax error in the stylesheet by one of the modules you’ve installed.
The best way to track this down, is to disable each module one-by-one and load /icingaweb2/css/icinga.css in the browser after each. Once this doesn’t error anymore, you’ve found the erroneous module.
If it’s one made by Icinga, please open a bug report on Github.
Thank you, after disabling the buisnessorocess modul - all is fine.
Hello ,
This is the solution , its works after disabling the businesproess module
I have disabled every single module on my installation (even the default provided ones) and i am still having issues.
I finally figured it out
In my case it was /usr/share/icingaweb2/public/css/themes/Dark.less and Dark2.less
Could be i had them installed years ago by hand. Deleting the files fixed my problems.
Still, better error message would help A LOT. I’ve been going crazy over this for the better part of last 2 months.
Glad you figured it out! I was about to reply telling you that v2.9.4 includes changes for better error reporting in this regard. (At least by opening /icingaweb2/css/icinga.css)
yeah, it was not ideal, but it gave me a hint to look at css files instead.
