Adjusting alert thresholds?
I’m setting up a load monitor/check on a host that is used as a Proxmox hypervisor that runs several VMs. Load is always higher than other hosts, given the nature of the beast. I’ve set up a monitor on that host that constantly alerts due to high load and latency. Is there a way to adjust what threshold the load check starts alerting on?
Oh, and I’m pretty much a noob to Icinga2, but I managed to get it all working, thus far. So, apologies in advance if there is a well-known way of doing this and I just haven’t been able to find out how.
Cheers!
Randy
See https://icinga.com/docs/icinga2/latest/doc/10-icinga-template-library/
#load
Antony.
Thank you! I’ll work on adding those optional fields!
