Addition assignment for variables in arrays
Hello Folks,
I try to approach something like this in notifications:
Apply:
apply Notification "mail-service" to Service {
  import "mail-service-notification-template"
  user_groups += [ service.vars.notification.mail_contacts.groups ]
  assign where service.vars.notification.mail_contacts.groups
Template notication 1:
template Service "notification-mail-departmentA-service" {
enable_flapping = true
        vars.notification["mail_contacts"] = {
        groups = [ "departmentA" ]
Template notication 2:
template Service "notification-mail-departmentB-service" {
        groups = [ "departmentB" ]
Template service check:
template Service "check_A_template" {
import "notification-mail-departmentA-service"
check_command = "..."
template Service "check_B_template" {
import "notification-mail-departmentB-service"
template Service "check_AB_template" {
How could I solve it, without using too many apply rules? Many thanks in advance!
Best regards
David
Hi @parad1se
I think that the groups will be overwritten if you do it like this. Maybe this works:
// for template Service departmentB
vars.notification["mail_contacts"].groups += "departmentB"
Kind regards
Hi @ritzgu
thanks for the suggestion, this is the result which I get with:
Result:
[2021-03-23 10:09:41 +0100] critical/config: Error: Error while evaluating expression: Operator + cannot be applied to values of type 'Array' and 'String'
Also tried:
// for template Service departmentA
vars.notification["mail_contacts"].groups += "departmentA"
Result:
[2021-03-23 10:12:12 +0100] critical/config: Error: Validation failed for object ‘xxx!mail-Service’ of type ‘Notification’; Attribute ‘user_groups’: Object ‘departmentAdepartmentB’ of type ‘UserGroup’ does not exist.
As it seems nothing can be additional added to a array from a Host/Service var-Variable / Array. Or is there syntax for this case?
Best regards
David
Whoops, my bad.
vars.notification["mail_contacts"].groups += [ "departmentB" ]
Its working with:
And changed apply rule to:
  user_groups += service.vars.notification.mail_contacts.groups
Result on IcingaWeb2:
Custom Variables
  • mail_contacts => {
    • groups =>
      • departmentA
      • departmentB}|
Thank you ritzgu! This is the solution.
I am glad I have found your post.
