Hi, new to Icinga, and while I’ve able to add hosts etc and monitoring is work fine, I’m really confused about how to install the reporting module so I get get some historical reports out. I’ve read the installtion section, but cant seem to work out how to get past the “Install it like any other module” as I can’t seem to find any simple instructions that say howto dio this. I did find ( and try) this https://icinga.com/blog/2019/06/17/icinga-reporting-hands-on/ and while this did show up in the icingaweb2 modules, it just display a lot of errors, so I suspect is out of date. Any help for a newbe welcomed.
Just to get this right: You’ve noticed that this is a link leading to Modules - Icinga Web ?
Yes, we have Icinga web2 deployed and working, e.g. we can and are monitoring hosts, so I guess my question is, where do I get the reporting module from, and how does one install it. I’ve Googled and read lots of pages, but I must be missing the first step, e.g. installing the module, (its probably obvious, but I’m clearly missing something.)
Just follow Johannes’
and choose for example the “Sample GIT installation” ![]()
In the link that you referenced there is also the link to the github project which you can clone.
ta, that worked adn I was able to install the reporting module and ir appears in web console of Icinga, but when I do anything, I get this error
Uncaught Error: Class ‘ipl\Web\Compat\CompatController’ not found in /usr/share/icingaweb2/modules/reporting/library/Reporting/Web/Controller.php:9
Stack trace:
#0 /usr/share/php/Icinga/Application/ClassLoader.php(303): require()
#1 [internal function]: Icinga\Application\ClassLoader->loadClass()
#2 /usr/share/icingaweb2/modules/reporting/application/controllers/ReportsController.php(18): spl_autoload_call()
#3 /usr/share/php/Icinga/Application/ClassLoader.php(303): require(’/usr/share/icin…’)
#4 [internal function]: Icinga\Application\ClassLoader->loadClass()
#5 [internal function]: spl_autoload_call()
#6 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(55): class_exists()
#7 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch()
#8 /usr/share/php/Icinga/Application/Web.php(300): Zend_Controller_Front->dispatch()
#9 /usr/share/php/Icinga/Application/webrouter.php(99): Icinga\Application\Web->dispatch()
#10 /usr/share/icingaweb2/public/index.php(
#0 [internal function]: Icinga\Application\Web->Icinga\Application{closure}()
#1 {main}
any idea what this means?
I think you might be missing some requirements for the reporting module.
Check, if you have all needed packages/modules installed ![]()
