Add Property Modifier in Import Source via own module
Hello Community,
I try to write an own icingaweb2 director import rule property.
First of all I created a new folder structure:
[root@localhost]# pwd
/usr/share/icingaweb2/modules/directorextension
After that I copied the regex replace property php file into my new folder and renamed it to PropertyModifierTestProperty.php
[root@msd-ic-web01 directorextension]# tree
├── library
│   └── Director
│       └── ProvidedHook
│           └── Director
│               └── PropertyModifier
│                   └── PropertyModifierTestProperty.php
├── LICENSE
├── module.info
└── run.php
5 directories, 4 files
Now I changed the Classname and the Namespace:
<?php
namespace Icinga\Module\Directorextension\PropertyModifier;
use Icinga\Module\Director\Hook\PropertyModifierHook;
use Icinga\Module\Director\Web\Form\QuickForm;
class PropertyModifierTestProperty extends PropertyModifierHook
    public static function addSettingsFormFields(QuickForm $form)
        $form->addElement('text', 'pattern', array(
            'label'       => 'Regex pattern',
            'description' => $form->translate(
                'The pattern you want to search for. This can be a regular expression like /^www\d+\./'
            'required'    => true,
        $form->addElement('text', 'replacement', array(
            'label'       => 'Replacement',
                'The string that should be used as a preplacement'
    public function getName()
        return 'This is a test';
    public function transform($value)
        return preg_replace(
            $this->getSetting('pattern'),
            $this->getSetting('replacement'),
            $value
At last, I created the run.php and the module.info file
<?php
$this->provideHook('director/PropertyModifierTestProperty');
Now I activated my module in icingaweb.
I thought now, that I’m able to see my new property in the Import Source Property Modifier list, but its missing.
Hope someone can give me a short hint.
Cheers, Morde
The one thing I see is the Library/Director which has to be the name of your Module so Library/Directorextension. But I know no example for a module using this hook, so this is the only idea I have.
Hello Dirk,
thank you very much for your answer.
I moved the folder library\Director to library\Directorextension but unfortunately it is still not in my property modifier list.
├── library
│   └── Directorextension
│       └── ProvidedHook
│           └── Director
├── LICENSE
├── module.info
└── run.php
To debug the problem I created a new PropertyModifer in the directory module:
cp /usr/share/icingaweb2/modules/directorextension/library/Directorextension/ProvidedHook/Director/PropertyModifier/PropertyModifierTestProperty.php /usr/share/icingaweb2/modules/director/library/Director/PropertyModifier/
After that, I changed the namespace in the file and checked for the new Property. But my Test Property wasn’t there.
Now I found the following file: /usr/share/icingaweb2/modules/director/register-hooks.php
In this file are all Modifier Classes listed in an array.
I added my new class to this file, and voilà, I was able to use my Property.
I see no way to expand this file from my module. So I think it is not possible to add new Properties by a module.
Is anyone able to confirm this?
Ah, now I start to remember, so much time has passed since I contributed a modifier there.
I do not think the file is the magic, but the function provideHook.
If you change your run.php to look like this, it could do the trick:
$this->provideHook('director/PropertyModifier', PropertyModifierTestProperty::class);
Well, that changed something :smiley:
But the framework do not load my class.
I added this line as well to the run.php, but nothing changed:
use Icinga\Module\Directorextension\PropertyModifierPropertyModifierTestProperty;
I got it!
Change /usr/share/icingaweb2/modules/directorextension/library/Directorextension/ProvidedHook/Director/PropertyModifier/PropertyModifierTestProperty.php to contain:
namespace Icinga\Module\Directorextension\ProvidedHook\Director\PropertyModifier;
and /usr/share/icingaweb2/modules/directorextension/run.php to
use Icinga\Module\Directorextension\ProvidedHook\Director\PropertyModifier\PropertyModifierTestProperty;
That works really nice. Thank you very much!
