Been running Icinga2 for a few years now, and love it - so firstly thanks for a great piece of software!
For quite a while now I have been unable to acknowledge warnings via the icingaweb2 UI. I found this bug which looks very similar to what I am seeing, but it says that was resolved in v2.4.2.
I am currently running v2.6.2 of icingaweb2. And the icinga2 daemon version is;
icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.2-1)
Copyright (c) 2012-2018 Icinga Development Team (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 8 (jessie)
Kernel: Linux
Kernel version: 4.15.18-11-pve
Architecture: x86_64
do you have icinga2 clustered and added both masters as an api connection endpoint in icingaweb2?
Did you try to enable debug log and see the acknowledge?
Please post your commandtransports.ini and your api user configuration for icingaweb2 user (api-users.conf),
I am not running clustered, I just have a couple of LXC containers on my Proxmox host, one running the daemon (mon01) and the other running icingaweb2 (web01).
[icinga2]
transport = "remote"
host = "mon01"
port = "22"
user = "mon"
path = "/var/run/icinga2/cmd/icinga2.cmd"
I can’t find any *api-user.conf" on web01, only on mon01 (where the daemon runs) and that contains a couple of entries only;
you should start using the API as command transport, see the docs for more information how to enable it. I think the external commnad reader feature will be dropped soon.
Just one more thing to add: @anon66228339 is right about the commandpipe feature being deprecated in the future. But it always had one drawback that might have hit you: You always had to run Icinga Web 2 on the same host as the Icinga 2 instance you wanted to communicate with. That’s history when using the API.
