We use icinga2 monitoring to monitor all our infrastructure, we want to set a dashboard with some items without authentication, i have read the documentation again but i didn’t find anything related to that, is there a solution to set a dashboard without authentication ?
you can create a specific read-only role in Icinga Web 2, and assign a user for it. Next up, create a specific VHost configuration inside Apache/Nginx and restrict access based on IP addresses or something similar. Set REMOTE_USER as env variable to that restricted user name. The last thing where I am not sure if required is to also have an auth backend with the type external as additional fallback resource.
I’m not 100% sure the above works, but at least worth a try.
I think we are gonna choose grafana with Status Panel cause it’s the best option for us, the documentation isn’t clear about that, i will open an issue about it.
We went that way (Apache/VirtualHost) to feed our big screen monitors.
In authentication.ini, we have two types of authentication configured. First [icingaweb_ldap] is for regular users, and second [autologin] backend = external is for the screen user with monitoring restricted access.
