A distro agnostic guide to Graphite with venv (examples: RHEL8, Debian10, Ubuntu18)
Fixed my PATH and PID errors in the systemd config, changed a few warnings about carbon.conf, and tested this guide on Ubuntu 20.04.
@blakehartshorn
(graphite) $ pip install --upgrade pip wheel setuptools gunicorn whisper
(graphite) $ pip install carbon --install-option="--prefix=/opt/graphite" --install-option="--install-lib=/opt/graphite/lib"
(graphite) $ pip install graphite-web --install-option="--prefix=/opt/graphite" --install-option="--install-lib=/opt/graphite/webapp"
When installing on a new Ubuntu 20.04 vm these commands throw errors:
not sure what the problem with the first one is, as it seems to do what it is supposed to.
(graphite) carbon@icinga:~$ pip install --upgrade pip wheel setuptools gunicorn whisper
Collecting pip
  Downloading pip-20.3.3-py2.py3-none-any.whl (1.5 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 1.5 MB 3.2 MB/s
Collecting wheel
  Downloading wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting setuptools
  Downloading setuptools-51.1.1-py3-none-any.whl (2.0 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 2.0 MB 6.7 MB/s
Collecting gunicorn
  Downloading gunicorn-20.0.4-py2.py3-none-any.whl (77 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 77 kB 5.4 MB/s
Collecting whisper
  Downloading whisper-1.1.7.tar.gz (37 kB)
Collecting six
  Downloading six-1.15.0-py2.py3-none-any.whl (10 kB)
Building wheels for collected packages: whisper
  Building wheel for whisper (setup.py) ... error
  ERROR: Command errored out with exit status 1:
   command: /opt/graphite/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-spt3z2lp/whisper/setup.py'"'"'; __file__='"'"'/tmp/pip-install-spt3z2lp/whisper/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-fw6z792c
       cwd: /tmp/pip-install-spt3z2lp/whisper/
  Complete output (6 lines):
  usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
     or: setup.py --help [cmd1 cmd2 ...]
     or: setup.py --help-commands
     or: setup.py cmd --help
  error: invalid command 'bdist_wheel'
  ERROR: Failed building wheel for whisper
  Running setup.py clean for whisper
Failed to build whisper
Installing collected packages: pip, wheel, setuptools, gunicorn, six, whisper
  Attempting uninstall: pip
    Found existing installation: pip 20.0.2
    Uninstalling pip-20.0.2:
      Successfully uninstalled pip-20.0.2
  Attempting uninstall: setuptools
    Found existing installation: setuptools 44.0.0
    Uninstalling setuptools-44.0.0:
      Successfully uninstalled setuptools-44.0.0
    Running setup.py install for whisper ... done
Successfully installed gunicorn-20.0.4 pip-20.3.3 setuptools-51.1.1 six-1.15.0 wheel-0.36.2 whisper-1.1.7
(graphite) carbon@icinga:~$ pip install carbon --install-option="--prefix=/opt/graphite" --install-option="--install-lib=/opt/graphite/lib"
/opt/graphite/lib/python3.8/site-packages/pip/_internal/commands/install.py:234: UserWarning: Disabling all use of wheels due to the use of --build-option / --global-option / --install-option.
  cmdoptions.check_install_build_global(options)
ERROR: Location-changing options found in --install-option: ['--prefix', '--install-lib'] from command line. This is unsupported, use pip-level options like --user, --prefix, --root, and --target instead.
pip has been updated in he meantime to not support these options:
As I am pretty inexperienced with python/pip I have no idea how to work around that :sweat:
Hi.
Recently I had the same problem.
For the sake of simplicity, I downgraded pip (e.g. to pip 9).
Greetings
Thanks for the hint.
Did that and it worked. So basically one could simply leave out the β€œpip” from the first upgrade command and it should be ok (for now)
