About
This module allows you to easily add and change coordinates with the Icinga Director on openstreetmap using leaflet.js. With the opencage geocoder integration of the map module it is possible to search for addresses or POI’s.
Installation
The Module can be found here
How to install the module can be found here
To Do’s
If you like the module and maybe you have altered in some kind of way you want the community to know please write a guide
in written form or share a screencast
how you integrated it into your environment.
