139 error code for API - when trying to start icinga2 service in agent based mode
Hello
I have installed Icinga2 on RHEL 7.8 Maipo.
Agentless monitoring is configured and lauched succesfully under /etc/icinga2/conf.d.
However, when it comes to switching to agent based monitoring (with target approach combining both) i get 139 error code when trying to start icinga2.service - every time API is enabled.
What i did, is launched node wizard for master:
Master zone name [master]: agentbased
Do you want to specify additional global zones? [y/N]: n
Do you want to disable the inclusion of the conf.d directory [Y/n]: y
My config:
1. icinga2 daemon -C :
(there are warnings for 2 directories i initally created but later deleted under /etc/inga2/zones.d.
[2020-09-02 08:45:10 +0000] information/cli: Icinga application loader (version: 2.11.4-1)
[2020-09-02 08:45:10 +0000] information/cli: Loading configuration file(s).
[2020-09-02 08:45:10 +0000] warning/config: Ignoring directory '/var/lib/icinga2/api/zones/agentbased1' for unknown zone 'agentbased1'.
[2020-09-02 08:45:10 +0000] warning/config: Ignoring directory '/var/lib/icinga2/api/zones/master' for unknown zone 'master'.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Committing config item(s).
[2020-09-02 08:45:10 +0000] information/ApiListener: My API identity: linuxserver.domain.com
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 FileLogger.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 NotificationComponent.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 IcingaApplication.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 ApiListener.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 CheckerComponent.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 3 Zones.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 Endpoint.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 ApiUser.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2020-09-02 08:45:10 +0000] information/ConfigItem: Instantiated 235 CheckCommands.
[2020-09-02 08:45:10 +0000] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2020-09-02 08:45:10 +0000] information/cli: Finished validating the configuration file(s).
2. icinga2 --version :
icinga2 - The Icinga 2 network monitoring daemon (version: 2.11.4-1)
Copyright (c) 2012-2020 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Red Hat Enterprise Linux Server
  Platform version: 7.8 (Maipo)
  Kernel: Linux
  Kernel version: 3.10.0-1127.13.1.el7.x86_64
  Architecture: x86_64
Build information:
  Compiler: GNU 4.8.5
  Build host: runner-ltrjqz9n-project-322-concurrent-0
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
3. /etc/icinga2/icinga2.conf :
include "constants.conf"
include "zones.conf"
include <itl>
include <plugins>
include <plugins-contrib>
include <manubulon>
include <windows-plugins>
include <nscp>
include "features-enabled/*.conf"
// Disabled by the node setup CLI command on 2020-08-28 13:58:37 +0000
// include_recursive "conf.d"
// Added by the node setup CLI command on 2020-07-30 09:38:56 +0000
include "conf.d/api-users.conf"
Would highly appreciate any tip for which direction to search
What does your zones.conf and constants.conf look like?
Hello Roland, they are as follows:
cat /etc/icinga2/zones.conf :
 * on 2020-08-28 13:58:32 +0000
object Endpoint "linuxserver.domain.com" {
object Zone "agentbased" {
        endpoints = [ "linuxserver.domain.com" ]
        global = true
        global = true
cat /etc/icinga2/constants.conf :
 * This file defines global constants which can be used in
 * the other configuration files.
/* The directory which contains the plugins from the Monitoring Plugins project. */
const PluginDir = "/usr/lib64/nagios/plugins"
At least NodeName and ZoneName is missing in your constants.conf. Example:
const PluginDir = "/usr/lib/nagios/plugins"
/* The directory which contains the Manubulon plugins.
 * Check the documentation, chapter "SNMP Manubulon Plugin Check Commands", for details.
const ManubulonPluginDir = "/usr/lib/nagios/plugins"
/* The directory which you use to store additional plugins which ITL provides user contributed command definitions for.
 * Check the documentation, chapter "Plugins Contribution", for details.
const PluginContribDir = "/usr/lib/nagios/plugins"
/* Our local instance name. By default this is the server's hostname as returned by `hostname --fqdn`.
 * This should be the common name from the API certificate.
const NodeName = "icinga.example.com"
/* Our local zone name. */
const ZoneName = "icinga.example.com"
/* Secret key for remote node tickets */
const TicketSalt = "***"
I am sorry, didnt paste full constant.conf previously, it should be:
const ManubulonPluginDir = "/usr/lib64/nagios/plugins"
const PluginContribDir = "/usr/lib64/nagios/plugins"
const NodeName = "linuxserver.domain.com"
const ZoneName = "agentbased"
Only two ideas left from my side: Check your certificates as described here. And check if the hostname is properly resolved e.g. /etc/hosts or nameserver.
Thanks Roland
  1. will check certificate path
  2. as to /etc/hosts file, it contains only below localhost entries, no server name or fqdn:
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
However, hostname command resolves the host FQDN correctly
Roland,
  1. I’ve checked cert validation guide, but seems for me the problem starts earlier, as the icinga server doesnt even launch with api enabled
  2. Strange that there is nothing in the logs,
    i understand this 139 error means some memory segmentation violation
  3. Not sure why some of the old configs are moved to /var/lib/ and dont get removed:
Hi again
Did another test icinga2 server installation on Ubuntu 20.04 laptop and everything seems fine.
Will try to connect another Windows laptop as client over Wifi on Monday
One thing wonders me, if node wizard has a choice to disable conf.d, then how icinga gets the api-users details then?
I reinstalled icinga on Red Hat (removed all icinga* pkgs + removed /etc/icinga2 directory),
And, after reinstallation & master node wizard setup - again got the 139 error code.
But after api feature flop (off-on) service finally started running.
However, comparing to the healthy Ubuntu server, i cannot see any process listening on 5665, therefore any client installation cannot connect
api-users.conf is usually added directly.
I’m not familiar with RHEL but I know it is using SELinux and this might have an impact here.
Thanks Roland, as replied also in another thread below, disabling SE Linux helped
https://community.icinga.com/t/icinga-process-not-listening-on-5665/5483/3
