I haven’t touched this file.
This is on the master:
* The constants.conf defines global constants.
include "constants.conf"
* The zones.conf defines zones for a cluster setup.
* Not required for single instance setups.
include "zones.conf"
* The Icinga Template Library (ITL) provides a number of useful templates
* and command definitions.
* Common monitoring plugin command definitions are included separately.
include <itl>
include <plugins>
include <plugins-contrib>
include <manubulon>
* This includes the Icinga 2 Windows plugins. These command definitions
* are required on a master node when a client is used as command endpoint.
include <windows-plugins>
* This includes the NSClient++ check commands. These command definitions
include <nscp>
* The features-available directory contains a number of configuration
* files for features which can be enabled and disabled using the
* icinga2 feature enable / icinga2 feature disable CLI commands.
* These commands work by creating and removing symbolic links in
* the features-enabled directory.
include "features-enabled/*.conf"
* Although in theory you could define all your objects in this file
* the preferred way is to create separate directories and files in the conf.d
* directory. Each of these files must have the file extension ".conf".
// Disabled by the node setup CLI command on 2019-12-06 13:11:59 +0100
// include_recursive "conf.d"
// Added by the node setup CLI command on 2019-12-06 13:11:59 +0100
#include "conf.d/api-users.conf"
include_recursive "/etc/icinga2/conf.d/"
On the satellite it’s the same but the last line it’s just include_recursive "conf.d"
