Zone naming / endpoint best practice
Hey guys…
We are having a lot of zones since the beginning of our setup BUT we are facing an issue and I think it’s related to how we managed our zones!
In our zones.conf on the master we have
object Endpoint "sat01.fqdn" {
        host = "172.30.254.116"
object Zone "sat01.fqdn" {
  endpoints = [ "sat01.fqdn" ]
  parent = "master"
AND in our zones.conf in the sat01 we have
object Endpoint "master.fqdn" {
        host = "master.fqdn"
        port = "5665"
object Zone "master" {
        endpoints = [ "master.fqdn" ]
        parent = "master"
        global = true
        global = true
In the zones.conf of 1 agent we have
object Endpoint NodeName {
object Zone ZoneName {
        endpoints = [ NodeName ]
        parent = "master"
        global = true
object Zone "global-commands" {
        global = true
If for some reason, we need to replace OR add a new sat at the same location, we will named it
sat02.fqdn
by doing that, we would need to modify all the zones.conf on some agent to replace the sat01.fqdn
Is there a better way to handle that ? Right now we are replacing 4-5 “sat” and that means we need to change near 100 agent zone config for the new “sat” name…
thanks
