X509 Error after updating ICINGA DB
Good Morning,
i just updated my icinga system incl. the icinga db and updated the schema. I have the x509 module enabled and running. After the update i got an error in the icinga web 2 ui.
ERROR: InvalidArgumentException in /usr/share/icinga-php/ipl/vendor/ipl/orm/src/Resolver.php:676 with message: Cannot resolve relation path “chain.certificate”. Base table alias/name is missing.
On the first sight i did not see an other post here in the forum or at github. Can anyone help me?
Thanks.
what is your verison of x509?
Hi Christian,
sorry for the trouble, this seems to be a bug in x509 popping up only now. I opened an issue on our repository already and will push a fix in a few moments. It’s a simple fix, which you may apply prior release manually.
ah there was a release 1.2.0 of icinga-php-library, did not update to that
Thanks. Then i will wait for the fix to release.
