Hi Everyone,
I started defining explicit dependency between host and services and seeing wrong reporting where icinga says that host is in soft state for all the hosts which is obviously not true.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!agent-health!disable-service-notification' failed: Parent host 'prod-sg1-2.sg1.prod.node' is in a soft state.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!agent-health!disable-service-notification' passed: Parent host 'prod-sg1-2.sg1.prod.node' matches state filter.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!agent-health!disable-host-service-checks' passed: Parent host 'prod-sg1-2.sg1.prod.node' matches state filter.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!/!disable-host-service-checks' passed: Parent host 'prod-sg1-2.sg1.prod.node' matches state filter.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!/!disable-service-notification' failed: Parent host 'prod-sg1-2.sg1.prod.node' is in a soft state.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!/!disable-service-notification' passed: Parent host 'prod-sg1-2.sg1.prod.node' matches state filter.
[2020-12-08 16:25:58 +0000] notice/Dependency: Dependency 'prod-sg1-2.sg1.prod.node!/!agent-health-check' passed: Parent service 'prod-sg1-2.sg1.prod.node!agent-health' matches state filter.
These logs are reported for all the hosts and I am worried if my icinga config is wrong or impact the current system in anyways.
Here is my dependency config:
#Disable checks when host is down
apply Dependency “disable-host-service-checks” to Service {
parent_host_name = host.name
states = [ Up ]
disable_checks = true
disable_notifications = true
assign where true
I am using icinga version - r2.12.0-1
