So far so good. I have almost everything setup but I want more and push it to the limits
I have services running on some endpoints that spit out a job time value every +/- 6 seconds. What is the best way to get this value into icinga so it can be shown in a chart and is this 6 second interval doable ?
Any suggestions or tips to start with ?
The same chapter has some reference implementations for querying objects in various languages. These can be easily modified to just send a POST request towards an action URL endpoint. Or you’ll look into the source code from listed integrations. Pick a language you’re familiar with and start coding
