with icinga director. how is that possible? Currently everything i write into a customfield gets quoted.
Your Environment
Director version (System - About): 1.8.1
Version used (icinga2 --version): 2.11.3
Operating System and version: Debian GNU/Linux 10 (buster)
Enabled features (icinga2 feature list): api checker command ido-pgsql influxdb mainlog notification
Config validation (icinga2 daemon -C): (/)
ok, but this only applies to arguments passed to a command, right? But i need this feature as a separate variable to access the variable with the grafana plugin.
you could explain what you are trying to achieve so it’s easier for us to help you find a workaround. If others see the usefulness the probability of implementation is also much higher
