Using Powershell module with Kerberos Authentication
Hello together,
I am using Kerberos authentication to log into my IcingaWeb 2.
And i used to create my Hosts by using the Powershell Module from GitHub:
Now my problem is after is started to use kerberos i can no longer use the powershell module.
I turned it off to see wheter it is related, and it is.
So does anyone know how i can fix this? Is it for example possible to use a fallback mechanism?
OS: Centos 7
Kind Regards
Pascal
