Using a check result in Service/CheckCommand?
Is it possible to use a check result of a service in another service or checkcommand or any other ojbect ?
yes it is possible :slight_smile:
That’s cool. Can you please share an example ?
use icinga dsl in your check command
https://icinga.com/docs/icinga-2/latest/doc/18-library-reference/#get_service
function get_service(host_name, service_name);
https://icinga.com/docs/icinga-2/latest/doc/09-object-types/
last_hard_state
last_check_result->output
