The user in our the example should only to be able to see and react to monitoring results, but definitely not change something as vital as those options.
We tried to change user rights for the monitoring module, but as soon as the general access for monitoring is enabled for our test user, those options show up.
Is this a normal/wanted behavior or is there any way to enable the monitoring module for our basic users, without these (unwanted) options in system-health?
There is only this role for that particular user and after we disable all of those permissions above (as a test), the user interface is basically empty.
Forget about my previous post. The advice from nilmerg worked perfectly. I just didn’t notice that the options in system->monitoring-health are still displayed but can’t be changed by the test user anymore.
