Use influxdbwriter and influxdb2writer in parallel
Hi
We are thinking about switching from InfluxDB1 to InfluxDB2. It would be nice to test this for some time with icinga writing the performance data in parallel to InfluxDB 1 and 2 using influxdbwriter and influxdb2writer at the same time. Is this possible?
It should work (haven’t been trying it though).
as they are two separate features with separate config files, I also think, this should work.
