Want to upgrade Icinga2 but I don’t see 2.12 available in Icinga stable repo and I don’t see it in "epel"as well.
Any idea?
Any idea?
Yes, you should be using the icinga repo packages as opposed to epel:
https://icinga.com/docs/icinga-2/latest/doc/02-installation/#rhelcentosfedora-repositories
Yes, I used the repo provided but it can’t find the 2.12 packages. I changed the path but still it won’t find them.
Odd, are you sure your repo is configured correctly?
# cat /etc/yum.repos.d/ICINGA-release.repo
[icinga-stable-release]
name=ICINGA (stable release for epel)
baseurl=http://packages.icinga.com/epel/$releasever/release/
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ICINGA
exclude=
Output of yum --showduplicates list icinga2
Installed Packages
icinga2.x86_64 2.13.0-1.el7.icinga @icinga-stable-release
Available Packages
icinga2.x86_64 2.4.10-1.el7.centos icinga-stable-release
icinga2.x86_64 2.5.0-1.el7.centos icinga-stable-release
icinga2.x86_64 2.5.0-2.el7.centos icinga-stable-release
icinga2.x86_64 2.5.0-3.el7.centos icinga-stable-release
icinga2.x86_64 2.5.1-1.el7.centos icinga-stable-release
icinga2.x86_64 2.5.2-1.el7.centos icinga-stable-release
icinga2.x86_64 2.5.3-1.el7.centos icinga-stable-release
icinga2.x86_64 2.5.4-1.el7.centos icinga-stable-release
icinga2.x86_64 2.6.0-1.el7.centos icinga-stable-release
icinga2.x86_64 2.6.1-1.el7.centos icinga-stable-release
icinga2.x86_64 2.6.2-1.el7.centos icinga-stable-release
icinga2.x86_64 2.6.3-1.el7.centos icinga-stable-release
icinga2.x86_64 2.7.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.7.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.7.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.8.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.8.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.8.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.8.3-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.8.4-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.9.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.9.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.9.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.3-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.4-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.5-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.10.7-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.3-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.4-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.5-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.6-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.7-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.8-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.9-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.10-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.11.11-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.1-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.2-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.3-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.4-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.5-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.12.6-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.13.0-1.el7.icinga icinga-stable-release
icinga2.x86_64 2.13.1-1.el7.icinga icinga-stable-release
I ended running “yum localinstall” and the 2.11 pkg rpms. The repo didn’t help.
