I found the page on the Icinga docs site about upgrading and it has a lot of information but it doesn’t actually say how to do the upgrade. I have 2.11.2-1 and 2.7.3 Icingaweb, on CentOS. Do I just do a ‘yum update’ and then check for the database schema files to apply? Thanks.
depending from which version you upgrade you should read the upgrade docs first and do all the needed steps after instsalling the update with yum. For Icinga you will find information additional steps to do for each version in the upgrade docs. same for icingaweb2.
Regards,
Carsten
