fl0wx
(Fl0w)
1
is it possible to upgrade icingaweb2 from 2.7 β 2.9 without ugprading Icinga Backend (2.11) ? And is it also possible to dont use icingadb with 2.9?
Greetings fl0w
- Icinga Web 2 version 2.7.3
- Icinga 2 version used (
icinga2 --version
) 2.11.3
- PHP version used (
php --version
) PHP 7.3.29-1~deb10u1
- Server operating system and version Debian 10
log1c
2
Never tried it, but I think that should work.
check the upgrading docs as well: https://icinga.com/docs/icinga-web-2/latest/doc/80-Upgrading/#upgrading-icinga-web-2
If you decide to try it be sure to do a DB backup and snapshot the servers
Not sure what you mean by that but:
- icinga web 2 2.8+ is ready for icingadb, but
β icingadb isnβt released yet (only a RC)
β Icinga IDO DB is still the default
- if you wanted to use icingadb you would have to update to icinga2 v2.12+
