Update Plugin Output Or Default Fields With Plugin Custom Var
Hello
This is similar topic as I have asked in the past - but still it is little different. ServiceNow Connector pulls specific fields from icinga
Following is the list:
last_check_result.output
groups
notes_url
performance_data
notes
last_state_up
address
check_command
Now we somehow have to pass oracle DB instance name in the output field or one of hte above fields.
I took a dump of the /object/serivices api for lets say oracle
            "attrs": {
                "__name": "hostname!P_OR_PDB_SwitchInterval",
                "acknowledgement": 0.0,
                "acknowledgement_expiry": 0.0,
                "action_url": "",
                "active": true,
                "check_attempt": 1.0,
                "check_command": "oracle_health",
                "check_interval": 300.0,
                "check_period": "",
                "check_timeout": null,
                "command_endpoint": "hostname",
                "display_name": "P_OR_PDB_SwitchInterval",
                "downtime_depth": 0.0,
                "enable_active_checks": true,
                "enable_event_handler": true,
                "enable_flapping": false,
                "enable_notifications": true,
                "enable_passive_checks": true,
                "enable_perfdata": true,
                "event_command": "",
                "flapping": false,
                "flapping_current": 27.4,
                "flapping_last_change": 0.0,
                "flapping_threshold": 0.0,
                "flapping_threshold_high": 30.0,
                "flapping_threshold_low": 25.0,
                "force_next_check": false,
                "force_next_notification": false,
                "groups": [],
                "ha_mode": 0.0,
                "handled": false,
                "host_name": "hostname",
                "icon_image": "",
                "icon_image_alt": "",
                "last_check": 1594201220.619314,
                "last_check_result": {
                    "active": true,
                    "check_source": "hostname",
                    "command": [
                        "/usr/lib//nagios/plugins/check_oracle_health",
                        "--connect",
                        "abcdef_instance",
                        "--mode",
                        "switch-interval",
                        "--report",
                        "long",
                        "--username",
                        "secrete_user"
                    "execution_end": 1594201220.61927,
                    "execution_start": 1594201219.236873,
                    "exit_status": 2.0,
                    "output": "CRITICAL - cannot connect to abcdef_instance. ORA-01017: invalid username/password; logon denied (DBD ERROR: OCISessionBegin)",
                    "performance_data": [],
                    "schedule_end": 1594201220.619314,
                    "schedule_start": 1594201220.619314,
                    "state": 2.0,
                    "ttl": 0.0,
                    "type": "CheckResult",
                    "vars_after": {
                        "attempt": 1.0,
                        "reachable": true,
                        "state": 2.0,
                        "state_type": 0.0
                    "vars_before": {
                        "attempt": 1.0,
                        "reachable": true,
                        "state": 0.0,
                        "state_type": 1.0
                "last_hard_state": 0.0,
                "last_hard_state_change": 1594200844.829981,
                "last_reachable": true,
                "last_state": 0.0,
                "last_state_change": 1594201220.610858,
                "last_state_critical": 1594201220.610879,
                "last_state_ok": 1594201141.470915,
                      "last_state_type": 1.0,
                "last_state_unknown": 0.0,
                "last_state_unreachable": 0.0,
                "last_state_warning": 1594199598.625638,
                "max_check_attempts": 3.0,
                "name": "P_OR_PDB_SwitchInterval",
                "next_check": 1594201279.760888,
                "notes": "",
                "notes_url": "",
                "original_attributes": null,
                "package": "director",
                "paused": true,
                "previous_state_change": 1594200844.829981,
                "problem": true,
                "retry_interval": 60.0,
                "severity": 136.0,
                "source_location": {
                    "first_column": 1.0,
                    "first_line": 242.0,
                    "last_column": 43.0,
                    "last_line": 242.0,
                    "path": "/var/lib/icinga2/api/packages/director/fcec207d-89a1-407d-a4f3-2231794c1a70/zones.d/Satellite_INF/service_apply.conf"
                "state": 2.0,
                "state_type": 0.0,
                "templates": [
                    "tmplService-OraHealth",
                    "host var overrides (Director)"
                "type": "Service",
                "vars": {
                    "oracle_health_connect": "abcdef_instance",
                    "oracle_health_mode": "switch-interval",
                    "oracle_health_username": "secret_user"
                "version": 0.0,
                "volatile": false,
                "zone": "Satellite_INF"
            "joins": {},
            "meta": {},
            "name": "hostname!P_OR_PDB_SwitchInterval",
            "type": "Service"
This is basically a single service which has been overridden for each instance of monitoring. This alert is for Oracle instance abcdef_instance. I want to somehow pass this information in one of the default fields mentioned above which servicenow pulls. Can I write in the serrvice-template of P_OR_PDB_SwitchInterval under lets say in output
Long Story Short:
I want to somehow pass like this without touching the plugin
“output”: $oracle_health_connect$ + “CRITICAL - cannot connect to abcdef_instance. ORA-01017: invalid username/password; logon denied (DBD ERROR: OCISessionBegin)”,
And this information will be populated on specific instance name of the field
