From Icingaweb2, I can see UNKNOWN (unhandled) services that are nor defined in the Icinga2 configuration. The services name visible in Icingaweb2 does not exist in the ‘icinga2 object list’.
I made a lot of tests to be sure I do not generate such services in my config and of course I also restarted all services … nothing to do, services still appear in Icingaweb2. I also search potential traces of these services name in the Icinga2 config. and runtime files (/var, /etc/, …) on the disk and they don’t! I am wondering if there is an Icingaweb2 cache or persistent config. somewhere separate from the Icinga2 config.?
Thank you in advance for your help
Frank
IcingaWeb2: 2.5.0
Icinga: 2.12.2.1
OS: Linux CentOS 7
Web browser: Firefox
(same behaviour from Icingaweb2 running on Windows 10, Google Chrome)
