Trying to monitor a windows host.
object CheckCommand "check_win_disk_free" {
import "nrpe"
vars.nrpe_command = "CheckDriveSize"
vars.nrpe_no_ssl = true
vars.nrpe_arguments = "CheckAll=5 MinWarnFree=10 MinCritFree=3 FilterType=FIXED"
is putting out
'/usr/lib64/nagios/plugins/check_nrpe' '-H' 'hostname.domain.com' '-c' 'CheckDriveSize' '-n' '-a' 'CheckAll=5 MinWarnFree=10 MinCritFree=3 FilterType=FIXED'
I am looking to get something like
/usr/lib64/nagios/plugins/check_nrpe' '-H' 'edmtestappp01.adcu.columbia.edu' -c CheckDriveSize -n -a -t 120 -a CheckAll=5 MinWarnFree=10 MinCritFree=3 FilterType=FIXED
Obviously new at this, but the docs are sending me into a bit of a trial and error loop i can’t break from. And I’m sorry but I cannot use the director as my org will not endorse it. I must keep this as close to Nagios as possible or they will scrap it.
Thanks for any help.
