I have a notification as below which works great. My problem is that the script is triggered twice.
The first time when the problem occurs and a second time when the problem has been recovered
Sending reminder 'Problem' notification
Sending 'Recovery' notification
How can I stop icinga2 from sending the Recovery notification for this specific notification, please? In this case from WARNING to OK
template NotificationCommand "empty_json_file-template-service" {
import "plugin-notification-command"
command = [ "/usr/lib64/nagios/plugins/empty_json_file" ]
object NotificationCommand "empty_json_file-service" {
import "empty_json_file-template-service"
apply Notification "Empty-JSON-file" to Service {
command = "empty_json_file-service"
users = ["opsgenie"]
states = [ Warning ]
interval = 0
times.begin = 1m
assign where host.name == "SOME_HOSTNAME" && service.name == "Storage"
