Soft State, different color
Hi there
I would like to have a different color for soft states, how can this be done?
It seems class wise both soft and hard fails choose “state-down”.
Cheers
typically color changes need to be done in a custom theme, just like the example company theme shows.
The class you’re looking for is built from a stateful mixin.
So in that case, set color-down-handled resp. color-critical-handled to a different value in your theme.
Hi Michael
Thank you for your fast reply, however my problem is, that soft and hard down both use “state-down”, id like to have a soft fail use a different color.
Cheers
Hey @ozzi! Perhaps you could upvote https://github.com/Icinga/icingaweb2/issues/4160 , if this is what you wanted?
