Hi there,
I am completely new to icinga and want to set up alerts based on polling network devices via SNMP v3.
Is there a good tutorial out there that explains how to do this?
Cheers
Hi there,
Cheers
Hello Noah,
I’m also quite new in Icinga2.
I would recommend you to use the plugins “check_nwc_health”.
When your can run it via shell, it is easier for you to implement it in Icinga.
Greetings
Gabriel
