Hi all,
This might be a basic question but I couldn’t figure it out or find it on the documentation.
Is it possible to set up a lambda function on a custom attribute as I would do in the file configuration:
“vars.os” : “{{ Math.random() * 100 }}”
But it sets the variable as a string.
otherwise it is not a valid json.
I have tried multiple variations but none of them have worked. Is there any way to make it work?
Thanks in advance.
