Hello all,
does anyone know a way how I can generate a CSV report that lists all service sets for me?
Best wishes
Hello all,
Best wishes
If you use icinga director you can get the query by:
https://your-icinga/icingaweb2/director/services/sets?format=sql
and you can export csv files via mysql:
SELECT
orderNumber, status, orderDate, requiredDate, comments
FROM
orders
WHERE
status = 'Cancelled'
INTO OUTFILE 'C:/tmp/cancelled_orders.csv'
FIELDS ENCLOSED BY '"'
TERMINATED BY ';'
ESCAPED BY '"'
LINES TERMINATED BY '\r\n';
source : https://www.mysqltutorial.org/mysql-export-table-to-csv…
Did that help solving your issue?
