Same service to more items not works
Hello!
icinga2, three machines:
  • server: VM, Roxy Linux 8, 2.13.2-1
  • client1: Physical, Debian 12.5, 5 disks, r2.14.2-1
  • client2: RPI, raspbian bookworm, 2 disks. r2.13.6-1
A SMART check would run on all of them.
object CheckCommand "check_smart_command" {
    import "plugin-check-command"
    command = [ "/bin/sudo", CustomPluginDir  + "/check_smart.pl" ]
    timeout = 1m
    arguments += {
        "-i" = {
            description = "Interface"
            value = "$checksmartinterface$"
        "-d" = {
            description = "Device Name"
            value = "$checksmartdevice$"
    vars.check_address = {
        arguments = [  ]
        deprecated = false
        name = "<anonymous>"
        side_effect_free = false
        type = "Function"
(command: https://www.claudiokuenzler.com/monitoring-plugins/check_smart.pl )
eervice template:
template Service "check_smart_linux_service" {
    check_command = "check_smart_command"
    check_period = "Everytime"
    command_endpoint = host_name
    host.vars.checksmartinterface = "auto"
    host.vars.checksmartdevice = ""
and service apply , now only for pi:
apply Service "SMART_LINUX_SDA"   {
    assign where "raspberrypi" == host.name
    import "check_smart_linux_service"
    host.vars.checksmartdevice = "/dev/sda"
    zone = "icinga2"
apply Service "SMART_LINUX_SDB"   {
    host.vars.checksmartdevice = "/dev/sdb"
    zone = "icinga2"
both check run on first disk ( if i have 5 disks - even only the first disk. If change sequence in sercvice.conf (first check sdb, second check sda), both check run in sdb. If rename /dev/sda to qwert and /dev/sdb to asdf - both check run on qwert (ok, non-existent, but try)
[2024-02-25 12:32:22 +0100] notice/Process: Running command '/bin/sudo' '/usr/local/lib/nagios/plugins/check_smart.pl' '-d' '/dev/sda' '-i' 'auto': PID 24653
[2024-02-25 12:32:23 +0100] notice/Process: PID 24653 ('/bin/sudo' '/usr/local/lib/nagios/plugins/check_smart.pl' '-d' '/dev/sda' '-i' 'auto') terminated with exit code 0
[2024-02-25 12:32:25 +0100] notice/Process: Running command '/bin/sudo' '/usr/local/lib/nagios/plugins/check_smart.pl' '-d' '/dev/sda' '-i' 'auto': PID 24662
[2024-02-25 12:32:26 +0100] notice/Process: PID 24662 ('/bin/sudo' '/usr/local/lib/nagios/plugins/check_smart.pl' '-d' '/dev/sda' '-i' 'auto') terminated with exit code 0
[Service Problems]
Soft 1/3 [SMART_LINUX_SDA]
Could not find any valid block/character special device for device qwert !
UNKNOWN
Soft 1/3 [SMART_LINUX_SDB]
change the sequence in services.conf:
    host.vars.checksmartdevice = "asdf"
    zone = "icinga2"
    host.vars.checksmartdevice = "qwert"
    zone = "icinga2"
Service: SMART_LINUX_SDA
Could not find any valid block/character special device for device asdf !
Service: SMART_LINUX_SDB
WHY? why does it only consider the parameter passed to the first one?
thanks for answer
Currently you are setting the variable host.vars.checksmartdevice in the first service definition and the overwrite it in the next, as it is not bound to the service due to the host. part.
If you change all your host.vars. to just vars. it should be fine, as the variable is now bound to the Service objects
oh…thx, i’ll try it. Not too simple, like nagios3 :slight_smile:
