Hi, running ssh checks from icinga to numerous hosts. i want to run a check (nagios plugin) twice a week, once on a thursday and once on a monday… how would i do this ? I can run it once a week by setting the check_interval in the templates file to 168hours. and if i halved that it would run it twice a week, but how do i know what days it will run it. say if i restart icinga.
thanks in advance.
you need to use timeperoids
object TimePeriod "MyTimePeriod" {
import "legacy-timeperiod"
ranges = {
"monday" = "08:00-08:45"
"thursday" = "08:00-08:45"
template Service "MyServiceTemplate" {
import "generic-service"
check_interval = 30m
check_period = "MyTimePeriod"
after that you use a service apply rule to add the service to the host
I don’t know if the check gets executed right when the time period starts, maybe you have to adjust the timeperiods or the check_interval.
many thanks… will give it a try
Hi im a bit confused… i have in templates.
object TimePeriod “MyTimePeriod” {
import “legacy-timeperiod”
ranges = {
“monday” = “08:00-08:45”
“thursday” = “08:00-08:45”
template Service “WeeklyCheck-Service” {
import “generic-service”
max_check_attempts = 5
retry_interval = 24h
check_timeout = 600s
And then my ssh check
apply Service "Satellite Subscription " {
import “WeeklyCheck-Service”
check_command = “by_ssh”
vars.by_ssh_logname = “root”
vars.by_ssh_options = “StrictHostKeyChecking=no”
// the [ ] syntax below joins the strings
vars.by_ssh_command = “/ns/tec/unix/u/patching/check_subscribed_status.sh”
vars.by_ssh_skip_stderr = 0
vars.by_ssh_timeout = 60
vars.by_ssh_arguments = {
assign where host.vars.os == “Linux7”
but when i look at the check in icinga2
ast check | on Nov 23 |
Next check | in 1d 19h Reschedule |
Check attempts | 1/5 (hard state) |
Check execution time | 1.691s |
Check latency | 0.085298s |
Check Timeperiod | MyTimePeriod |
I think its working… strange behaviour regarding “next check” but its run when i set it to… thanks.
so please mark my post as the solution to your problem
