I upgraded my Icinga2 host from Debian 8 to Debian 9. During the process I upgraded icinga 2 from r2.10.5-1 to r2.11.3-1 and icingaweb2 from 2.6.3 to 2.7.3. Everything looked fine until I logged out from icingaweb2 and refreshed the site. I seems like the stylesheet can not be loaded anymore.
When I try to open the css in the browser I get the following error message:
(/icingaweb2/css/icinga.min.css)
```Fatal error: Uncaught exception ‘Exception’ with message ‘.rotate is undefined: failed at .rotate(360deg);
line: 5585’ in /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php:3553 Stack trace: #0 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(2097): lessc_parser->throwError(’.rotate is unde…’, 189323) #1 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(720): lessc->throwError(’.rotate is unde…’) #2 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(283): lessc->compileProp(Array, Object(stdClass), Object(stdClass)) #3 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(221): lessc->compileProps(Object(stdClass), Object(stdClass)) #4 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(195): lessc->compileCSSBlock(Object(stdClass)) #5 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(691): lessc->compileBlock(Object(stdClass)) #6 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(283): lessc->compileProp(Array, Object(stdClass), Object(stdClass)) #7 /u in /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php on line 3553´´´
These are my enabled features:
api checker command graphite ido-mysql mainlog notification
Has anyone seen that before and can give me a hint? If you need more information just let me know.
Regards,
rba
