Retrive output from check_command
I created check command
object CheckCommand "check_interfaces" {
  command = [ "ip", "-br", "addr" ]
When create service
apply Service "intf" {
  host_name = "localhost"
  check_command = "check_interfaces"
  vars.stat = last_check_result.output
  command_endpoint = host.vars.agent_endpoint
  assign where host.vars.agent_endpoint
last_check_result in Host or Service objects always return “nul”. Same for last_check_result.output
Is there any way to use check_command output and apply service depend on that output?
  icinga2 - The Icinga 2 network monitoring daemon (version: 2.11.2-1)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
System information:
  Platform: CentOS Linux
  Platform version: 7 (Core)
  Kernel: Linux
  Kernel version: 3.10.0-957.27.2.el7.x86_64
  Architecture: x86_64
Build information:
  Compiler: GNU 4.8.5
  Build host: runner-LTrJQZ9N-project-322-concurrent-0
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
  • Enabled features (icinga2 feature list)
Disabled features: compatlog debuglog elasticsearch gelf graphite opentsdb perfdata statusdata syslog
Enabled features: api checker ido-pgsql influxdb mainlog notification
No, as the result and output are runtime variables which are not available during configuration compilation.
We had also similar challeng … I have ended up with developing wrapper written in python.
so the idea is wrapper.py → exec nagios_plugin → store results in variable of the wrapper.py → do evaluation and thresholding → send status to icinga with same or diff output msg.
or you can write your own icinga plugin for checking interface :slight_smile:
So, how/where i can use last_check_result?
For example when accessing objects during runtime to build your own cluster check: Advanced Topics - Icinga 2
