Reset notification attribute `no_more_notifications=true` to false
Hi all,
does anyone know if it is possible to reset the attribute no_more_notifications for a object?
Reason: I have a host object that has said variable set to true and therefore doesn’t send notifications anymore.
I believe the source for this is that the host was set into a downtime and therefore didn’t trigger the recovery notification:
Best regards
Logic :slight_smile:
Just found another hosts where this “problem” occurred.
After manually removing the downtime the UP notification was triggered and the attribute
no_more_notifications was set to false.
Any idea why this didn’t work when the downtime ended on its own?
Bug report created:
But this still does not resolve the host/services “stuck” with no_more_notifications=true.
No one got any idea how to reset those?
