found the following:
[2019-03-29 10:29:34 +0100] notice/Downtime: Added downtime 'vsm_sapcp2_db!ping4!70f54537-4cf6-4846-aad5-5a18b9a710b8' between '2019-04-01 05:45:00' and '2019-04-01 07:15:00'.
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Creating new Downtime for ScheduledDowntime "vsm_sapcp2!check_sap_availability_by_saprouter!reboot-system-vsmo"
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Finding running scheduled downtime segment for time 1553851774 (minEnd -)
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 april: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 august: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 december: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 february: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 january: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 july: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 june: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 march: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 may: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 november: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 october: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating (running?) segment: monday -1 september: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Finding next scheduled downtime segment for time 1553851774
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 april: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Apr 29 05:45:00 2019 -> Mon Apr 29 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: (best match yet)
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 august: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Aug 26 05:45:00 2019 -> Mon Aug 26 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 december: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Dec 30 05:45:00 2019 -> Mon Dec 30 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 february: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 january: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 july: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Jul 29 05:45:00 2019 -> Mon Jul 29 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 june: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Jul 1 05:45:00 2019 -> Mon Jul 1 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 march: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Apr 1 05:45:00 2019 -> Mon Apr 1 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 may: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon May 27 05:45:00 2019 -> Mon May 27 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 november: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Nov 25 05:45:00 2019 -> Mon Nov 25 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 october: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Oct 28 05:45:00 2019 -> Mon Oct 28 07:15:00 2019
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Evaluating segment: monday -1 september: 05:45-07:15
[2019-03-29 10:29:34 +0100] debug/ScheduledDowntime: Considering segment: Mon Sep 30 05:45:00 2019 -> Mon Sep 30 07:15:00 2019
[2019-03-29 10:29:34 +0100] notice/ConfigCompiler: Compiling config file: /var/lib/icinga2/api/packages/_api/aspbazinga04-1513244872-1/conf.d/downtimes/vsm_sapcp2!check_sap_availability_by_saprouter!d70e284f-6d54-49d1-a5cb-6295325547d9.conf
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_servicestatus SET acknowledgement_type = '0', active_checks_enabled = '1', check_command = 'ping4', check_source = 'aspbazinga.takeasp.de', check_type = '0', current_check_attempt = '1', current_notification_number = '0', current_state = '0', endpoint_object_id = 493, event_handler_enabled = '1', execution_time = '4.033288', flap_detection_enabled = '0', has_been_checked = '1', instance_id = 1, is_flapping = '0', is_reachable = '1', last_check = FROM_UNIXTIME(1553851774), last_hard_state = '0', last_hard_state_change = FROM_UNIXTIME(1553626658), last_notification = FROM_UNIXTIME(1552473522), last_state_change = FROM_UNIXTIME(1553626658), last_time_critical = FROM_UNIXTIME(1553626590), last_time_ok = FROM_UNIXTIME(1553851774), last_time_warning = FROM_UNIXTIME(1546284567), latency = '0.000352', long_output = '', max_check_attempts = '5', next_check = FROM_UNIXTIME(1553852005), next_notification = FROM_UNIXTIME(1553853512), normal_check_interval = '4', notifications_enabled = '1', original_attributes = 'null', output = 'PING OK - Packet loss = 0%, RTA = 9.81 ms', passive_checks_enabled = '1', percent_state_change = '0', perfdata = 'rta=9.806000ms;500.000000;1000.000000;0.000000 pl=0%;70;80;0', problem_has_been_acknowledged = '0', process_performance_data = '1', retry_check_interval = '1', scheduled_downtime_depth = '0', service_object_id = 1990, should_be_scheduled = '1', state_type = '1', status_update_time = FROM_UNIXTIME(1553851774) WHERE service_object_id = 1990
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_scheduleddowntime SET actual_start_time = FROM_UNIXTIME(1554090300), actual_start_time_usec = '0', author_name = 'icingaadmin', comment_data = 'Monatliche Wartung VSM-CP2', downtime_type = '1', duration = '0', endpoint_object_id = 493, entry_time = FROM_UNIXTIME(1553851774), instance_id = 1, internal_downtime_id = '34', is_fixed = '1', is_in_effect = '0', name = 'vsm_sapcp2!ping4!b485d3ce-f610-406a-be05-0c8121d1f681', object_id = 2239, scheduled_end_time = FROM_UNIXTIME(1554095700), scheduled_start_time = FROM_UNIXTIME(1554090300), session_token = 1553851712, was_started = '0' WHERE entry_time = FROM_UNIXTIME(1553851774) AND name = 'vsm_sapcp2!ping4!b485d3ce-f610-406a-be05-0c8121d1f681' AND object_id = 2239
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_servicestatus SET scheduled_downtime_depth = '0' WHERE instance_id = 1 AND service_object_id = 2239
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: INSERT INTO icinga_downtimehistory (actual_start_time, actual_start_time_usec, author_name, comment_data, downtime_type, duration, endpoint_object_id, entry_time, instance_id, internal_downtime_id, is_fixed, is_in_effect, name, object_id, scheduled_end_time, scheduled_start_time, was_started) VALUES (FROM_UNIXTIME(1554090300), '0', 'icingaadmin', 'Monatliche Wartung VSM-CP2', '1', '0', 493, FROM_UNIXTIME(1553851774), 1, '34', '1', '0', 'vsm_sapcp2!ping4!b485d3ce-f610-406a-be05-0c8121d1f681', 2239, FROM_UNIXTIME(1554095700), FROM_UNIXTIME(1554090300), '0')
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_scheduleddowntime SET actual_start_time = FROM_UNIXTIME(1554090300), actual_start_time_usec = '0', author_name = 'icingaadmin', comment_data = 'Monatliche Wartung VSM-CP2', downtime_type = '1', duration = '0', endpoint_object_id = 493, entry_time = FROM_UNIXTIME(1553851774), instance_id = 1, internal_downtime_id = '35', is_fixed = '1', is_in_effect = '0', name = 'vsm_sapcp2_appl01!Check TCP Port!7c9dc60f-92e8-4931-85fd-1172784e3d9d', object_id = 3021, scheduled_end_time = FROM_UNIXTIME(1554095700), scheduled_start_time = FROM_UNIXTIME(1554090300), session_token = 1553851712, was_started = '0' WHERE entry_time = FROM_UNIXTIME(1553851774) AND name = 'vsm_sapcp2_appl01!Check TCP Port!7c9dc60f-92e8-4931-85fd-1172784e3d9d' AND object_id = 3021
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_servicestatus SET scheduled_downtime_depth = '0' WHERE instance_id = 1 AND service_object_id = 3021
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: INSERT INTO icinga_downtimehistory (actual_start_time, actual_start_time_usec, author_name, comment_data, downtime_type, duration, endpoint_object_id, entry_time, instance_id, internal_downtime_id, is_fixed, is_in_effect, name, object_id, scheduled_end_time, scheduled_start_time, was_started) VALUES (FROM_UNIXTIME(1554090300), '0', 'icingaadmin', 'Monatliche Wartung VSM-CP2', '1', '0', 493, FROM_UNIXTIME(1553851774), 1, '35', '1', '0', 'vsm_sapcp2_appl01!Check TCP Port!7c9dc60f-92e8-4931-85fd-1172784e3d9d', 3021, FROM_UNIXTIME(1554095700), FROM_UNIXTIME(1554090300), '0')
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_scheduleddowntime SET actual_start_time = FROM_UNIXTIME(1554090300), actual_start_time_usec = '0', author_name = 'icingaadmin', comment_data = 'Monatliche Wartung VSM-CP2', downtime_type = '1', duration = '0', endpoint_object_id = 493, entry_time = FROM_UNIXTIME(1553851774), instance_id = 1, internal_downtime_id = '36', is_fixed = '1', is_in_effect = '0', name = 'vsm_sapcp2_db!ping4!70f54537-4cf6-4846-aad5-5a18b9a710b8', object_id = 3132, scheduled_end_time = FROM_UNIXTIME(1554095700), scheduled_start_time = FROM_UNIXTIME(1554090300), session_token = 1553851712, was_started = '0' WHERE entry_time = FROM_UNIXTIME(1553851774) AND name = 'vsm_sapcp2_db!ping4!70f54537-4cf6-4846-aad5-5a18b9a710b8' AND object_id = 3132
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: UPDATE icinga_servicestatus SET scheduled_downtime_depth = '0' WHERE instance_id = 1 AND service_object_id = 3132
[2019-03-29 10:29:35 +0100] debug/IdoMysqlConnection: Query: INSERT INTO icinga_downtimehistory (actual_start_time, actual_start_time_usec, author_name, comment_data, downtime_type, duration, endpoint_object_id, entry_time, instance_id, internal_downtime_id, is_fixed, is_in_effect, name, object_id, scheduled_end_time, scheduled_start_time, was_started) VALUES (FROM_UNIXTIME(1554090300), '0', 'icingaadmin', 'Monatliche Wartung VSM-CP2', '1', '0', 493, FROM_UNIXTIME(1553851774), 1, '36', '1', '0', 'vsm_sapcp2_db!ping4!70f54537-4cf6-4846-aad5-5a18b9a710b8', 3132, FROM_UNIXTIME(1554095700), FROM_UNIXTIME(1554090300), '0')
the files in /var/lib/icinga2/api/packages/_api/aspbazinga04-1513244872-1/conf.d/downtimes
object Downtime "b485d3ce-f610-406a-be05-0c8121d1f681" ignore_on_error {
author = "icingaadmin"
authoritative_zone = "wuerzburg"
comment = "Monatliche Wartung VSM-CP2"
config_owner = "vsm_sapcp2!ping4!reboot-system-vsmo"
duration = 0.000000
end_time = 1554095700.000000
entry_time = 1553851774.661778
fixed = true
host_name = "vsm_sapcp2"
scheduled_by = "vsm_sapcp2!ping4!reboot-system-vsmo"
service_name = "ping4"
start_time = 1554090300.000000
triggered_by = ""
version = 1553851774.661806
zone = "wuerzburg"
hope you can find anything, thank you
