I have currently a problem with my icinga2 configuration (version: 2.13.2-1). I want to configure a check to call an api. If I call the api with curl, I will get “USER:NO”
And then I have configured it for icinga and it works.
check_command = “http”
vars.http_vhost = host.name
vars.http_uri = “/api/xxx/xxx/check/”
vars.http_ssl = true
vars.http_string = “"USER":"NO"”
Then I think, maybe I can add a regex in “http_string”, for example if there is one or more spaces between “USER” and “NO”.
vars.http_string = “"USER":\s*"NO"”
From Icinga web I have seen the configuration, but I am not sure if it’s right.
http_string “USER”:\s*“NO”
But the check doesn’t work any more. And now I have a question, is the configuration incorrect or I need to enable sth. in icinga to get the regex work?
regards
