I am having a problem with a python script. Whenever Icinga executes it as a check a segmentation fault occurs but when I execute it manually in the servers there is no problem
/bin/lmstat: line 21: 25765 Segmentation fault $DIREC/linux/lmutil lmstat $*
Is SELinux configured? If yes, check the labels (ls -Z) and also the audit.log (/var/log/audit/audit.log) or the message log (/var/log/messages | grep SELinux) if there are denied access attempts.
