Problems with upgrading icinga 2.10.5 to 2.11 on FreeBSD
I tried yesterday to upgrade my icinga2. I run it on FreeBSD 11.3-p3 and it is currently on version 2.10.5.
After the upgrade “icinga2 daemon -C” doesn’t show any errors. But when I start the service, it starts and then exits pretty much immediately without any error messages. There are also no errors in the debug log.
I see that it sets already some checks to failed because of dependency fails and then the last message I see iseither :
[2019-09-24 14:54:29 +0200] information/ApiListener: U[2019-09-24 14:55:56 +0200] information/FileLogger: ‘debug-file’ started.
or
[2019-09-24 14:58:26 +0200] notice/ApiListener: Updated meta data for cluster config sync. Checksum: ‘/var/lib/icinga2/api/zones/icinga2-master-cluster/.checksums’, timestamp: ‘/var/lib/icinga2/api/zones/icinga2-master-cluster/.timestamp’, auth: ‘/var/lib/icinga2/api/zones/icinga2-master-cluster/.authoritative’.
[2019-09-24 14:58:26 +0200] information/ApiListener: Started new listener on ‘[::]:5665’
I read the upgrading FAQ but nothing really fits to my setup. Any ideas how I could debug this further?
Our feature list:
Disabled features: compatlog debuglog elasticsearch gelf graphite influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command ido-mysql mainlog notification
When I start it with icinga2 daemon -x debug and truss, I see the following:
[2019-09-25 08:50:29 +0200] information/DbConnection: 'ido-mysql' started.
[2019-09-25 08:50:29 +0200] information/ExternalCommandListener: 'command' started.
[2019-09-25 08:50:29 +0200] warning/ExternalCommandListener: This feature is DEPRECATED and will be removed in future releases. Check the roadmap at https://github.com/Icinga/icinga2/milestones
Context:
        (0) Activating object 'command' of type 'ExternalCommandListener'
[2019-09-25 08:50:29 +0200] information/NotificationComponent: 'notification' started.
[2019-09-25 08:50:29 +0200] information/CheckerComponent: 'checker' started.
[2019-09-25 08:50:29 +0200] information/ConfigItem: Activated all objects.
[2019-09-25 08:50:29 +0200] notice/WorkQueue: Stopped WorkQueue threads for 'DaemonCommand::Run'
nanosleep({ 0.200000000 })                       = 0 (0x0)
wait4(60659,{ SIGNALED,sig=64 },WNOHANG,0x0)     = 0 (0x0)
nanosleep({ 0.200000000 })                       ERR#4 'Interrupted system call'
SIGNAL 20 (SIGCHLD) code=CLD_KILLED pid=60659 uid=183 status=11
sigprocmask(SIG_SETMASK,{ SIGCHLD },0x0)         = 0 (0x0)
sigreturn(0x7fffffffca80)                        ERR#4 'Interrupted system call'
wait4(60659,{ SIGNALED,sig=SIGSEGV },WNOHANG,0x0) = 60659 (0xecf3)
[2019-09-25 08:50:29 +0200] notice/cli: Seemless worker (PID 60659) stopped, stopping as well
write(1,"[2019-09-25 08:50:29 +0200] \^[["...,103) = 103 (0x67)
unlink("/var/run/icinga2/icinga2.pid")           = 0 (0x0)
close(11)                                        = 0 (0x0)
_umtx_op(0x8010b2038,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2098,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b20e0,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b20f8,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2110,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2140,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2068,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2128,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8054182b8,UMTX_OP_NWAKE_PRIVATE,0x18,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2230,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2170,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2158,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2200,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x804020800,UMTX_OP_RW_WRLOCK,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2188,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b20c8,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x804020800,UMTX_OP_RW_UNLOCK,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b21a0,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b21e8,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2008,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b21d0,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2080,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2218,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2050,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b20b0,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x80552b5e0,UMTX_OP_MUTEX_WAIT,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b2020,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8010b21b8,UMTX_OP_WAIT_UINT_PRIVATE,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8055c09e0,UMTX_OP_MUTEX_WAIT,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x8055c09e0,UMTX_OP_MUTEX_WAKE2,0x0,0x0,0x0) = 0 (0x0)
_umtx_op(0x80552b5e0,UMTX_OP_MUTEX_WAKE2,0x0,0x0,0x0) = 0 (0x0)
munmap(0x8010c0000,4096)                         = 0 (0x0)
<thread 102033 exited>
munmap(0x8010be000,4096)                         = 0 (0x0)
<thread 102025 exited>
munmap(0x8010bf000,4096)                         = 0 (0x0)
<thread 102032 exited>        [72/4901]
munmap(0x8010c3000,4096)                         = 0 (0x0)
<thread 102096 exited>
munmap(0x8010c5000,4096)                         = 0 (0x0)
<thread 102213 exited>
munmap(0x8010c9000,4096)                         = 0 (0x0)
<thread 102241 exited>
munmap(0x8010c8000,4096)                         = 0 (0x0)
<thread 102240 exited>
munmap(0x8010ca000,4096)                         = 0 (0x0)
_umtx_op(0x805483e00,UMTX_OP_WAIT,0x18f63,0x0,0x0) = 0 (0x0)
<thread 102243 exited>
munmap(0x8010b9000,4096)                         = 0 (0x0)
_umtx_op(0x804020800,UMTX_OP_RW_UNLOCK,0x0,0x0,0x0) = 0 (0x0)        [18/4901]
<thread 101153 exited>
munmap(0x8010b4000,4096)                         = 0 (0x0)
<thread 100701 exited>
munmap(0x8010bd000,4096)                         = 0 (0x0)
munmap(0x8010bc000,4096)                         = 0 (0x0)
<thread 102024 exited>
munmap(0x8010bb000,4096)                         = 0 (0x0)
<thread 101278 exited>
<thread 101274 exited>
munmap(0x8010b8000,4096)                         = 0 (0x0)
<thread 101144 exited>
munmap(0x8010c7000,4096)                         = 0 (0x0)
munmap(0x8010c6000,4096)                         = 0 (0x0)
<thread 102239 exited>
_umtx_op(0x805484d00,UMTX_OP_WAIT,0x18f5f,0x0,0x0) = 0 (0x0)
munmap(0x8010ba000,4096)                         = 0 (0x0)
<thread 102236 exited>
<thread 101163 exited>
munmap(0x8010b7000,4096)                         = 0 (0x0)
munmap(0x8010b3000,4096)                         = 0 (0x0)
<thread 100918 exited>
<thread 100489 exited>
munmap(0x8010c1000,4096)                         = 0 (0x0)
munmap(0x8010b6000,4096)                         = 0 (0x0)
<thread 102035 exited>
<thread 100805 exited>
munmap(0x8010c2000,4096)                         = 0 (0x0)
munmap(0x8010b5000,4096)                         = 0 (0x0)
<thread 102036 exited>
<thread 100799 exited>
munmap(0x8010c4000,4096)                         = 0 (0x0)
<thread 102158 exited>
_umtx_op(0x805485c00,UMTX_OP_WAIT,0x18f0e,0x0,0x0) = 0 (0x0)
exit(0x8b)
process exit, rval = 139
when I disable the feature api it seems to work.
The config is this:
 * The API listener is used for distributed monitoring setups.
object ApiListener "api" {
  //cert_path = SysconfDir + "/icinga2/pki/" + NodeName + ".crt"
  //key_path = SysconfDir + "/icinga2/pki/" + NodeName + ".key"
  //ca_path = SysconfDir + "/icinga2/pki/ca.crt"
  ticket_salt = TicketSalt
  accept_config = false
After rerunning api setup, the startup failed because the root-user was defined in the global-templates and in conf.d. And the api setup added conf.d/api-users.conf
After fixing that, icinga2 worked until I tried to send a notification. That crashed it:
Caught unhandled exception.
Current time: 2019-09-25 09:27:51 +0200
  Application version: r2.11.0-1
System information:
  Platform: Unknown
  Platform version: Unknown
  Kernel: FreeBSD
  Kernel version: 11.3-RELEASE-p3
  Architecture: amd64
Build information:
  Compiler: Clang 8.0.0
  Build host: ic-11_3-RELEASE-HEAD-job-03
Application information:
General paths:
  Config directory: /usr/local/etc/icinga2
  Run directory: /var/run/icinga2
Old paths (deprecated):
  Installation root: /usr/local
  Sysconf directory: /usr/local/etc
  Run directory (base): /var/run
  Local state directory: /var
Internal paths:
  Package data directory: /usr/local/share/icinga2
  PID path: /var/run/icinga2/icinga2.pid
Error: Function call 'send' failed with error code 32, 'Broken pipe'
* This would indicate a runtime problem or configuration error. If you believe this is a bug in Icinga 2
* please submit a bug report at https://github.com/Icinga/icinga2 and include this stack trace as well as any other
* information that might be useful in order to reproduce this problem.
quit: No such file or directory.
ptrace: Operation not permitted.
//65707: No such file or directory.
-> GitHub issue please.
ok. I have done that. Let’s see how this works out
