I am noit really a Newby but I have a strange problem.
I will check with an external Perl Script the Snapshots on our Vcenter Server.
But the Variable I put in will not be used. Any idea whats wrong here?
log entry
warning/PluginCheckTask: Check command for object ‘servername!Snapshot Count’ (PID: 12428, arguments: ‘/usr/lib/nagios/plugins/check_vmware_snapshots.pl’ ‘–blacklist’ ‘host.vars.snapshot_blacklist’ ‘–critical’ ‘host.vars.snapshot_critical’ ‘–mode’ ‘host.vars.snapshot_mode’ ‘–server’ ‘host.vars.esxi_host’ ‘–warning’ ‘host.vars.snapshot_warning’) terminated with exit code 255, output: Value “host.vars.snapshot_critical” invalid for option critical (number expected)
object CheckCommand "check_vmware_snapshot" {
import "plugin-check-command"
command = [ PluginDir + "/check_vmware_snapshots.pl" ]
arguments = {
"--server" = "$esxi_host$",
"--username" = "$esxi_user$",
"--password" = "$esxi_pw$",
"--mode" = "$mode$",
"--warning" = "$warning$",
"--critical" = "$critical$",
"--blacklist" = "$blacklist$"
services.conf
apply Service "Snapshot Count" {
import "generic-service"
check_command = "check_vmware_snapshot"
vars.esxi_host = "host.vars.esxi_host"
vars.esxi_user = "$vcenteruser$"
vars.esxi_pw = "$vcenterpasswd$"
vars.mode = "host.vars.snapshot_mode"
vars.warning = "host.vars.snapshot_warning"
vars.critical = "host.vars.snapshot_critical"
vars.blacklist = "host.vars.snapshot_blacklist"
assign where host.vars.os == "vcenter"
Host.conf
object Host "servername" {
import "generic-host"
display_name = "servername"
address = "xxx.xxx.xxx.xxx"
vars.os = "vcenter"
vars.esxi_host = "servername"
vars.snapshot_mode = "count"
vars.snapshot_warning = 2
vars.snapshot_critical = 4
vars.snapshot_blacklist = "vtest-.*"
