Enabled features
Enabled features: api checker command compatlog debuglog ido-mysql livestatus mainlog notification perfdata statusdata
Icinga Web 2 version 2.6.1
Hello
We have a serious problem with non-executing checks on an Icinga 2.9 instance at a customer. It happened that the system time was inadvertently set to a future year (!) for a short time, which means that almost all Icinga services got a “last check” time stamp in the future. This has now led to a permanent state of non-execution of all affected services. How can we enforce checking to resume? (Setting “next check” to now, anywhere, or restoring the “icinga” database didn’t help!)
If this doesn’t work, I would imagine it’s reading for the next check from the state file or DB – you might need a way to clear out the last executed check timestamp from one or both of these locations (as well as the history for Icingaweb2 – those probably show future dates too I would imagine).
Off hand, I’m not sure if that information exists in the state file, database, or both, but iirc when Icinga2 restarts, it drops a lot of the db tables, and then populates them from the state file on start, so I would check there first. Also not sure if the db writes back to the state file, so maybe the DB is the place to start
Worst case scenario, if nothing works, set up a new master, move the object to the new master, reconnect any agents/zones to the new master and see if that helps – but again I would only treat that as a last resort.
