Hi
I’ve a problem on my icinga2 interface.
I can’t set a downtime on my differents hosts.
error:
icinga2: Can't send external Icinga command: 500 Action execution failed: 'Error: Could not create downtime object.
icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb livestatus opentsdb statusdata syslog
Enabled features: api checker ido-pgsql mainlog notification perfdata
On my /etc/icinga2/features-available/api.conf
object ApiUser "icingaweb2" {
password = "XXXXXXXXXX"
permissions = [
permission = "status/query"
permission = "actions/*"
permission = "objects/modify/*"
permission = "objects/query/*"
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.2-1)
I’m checking my config but not sure about the solution…
Thanks for help
Alex
